Ir para o conteúdo principal
LERSTA Floor Lamp Screw Terminal Replacement
O que você precisa
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: passo 1, imagem 1 %32 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: passo 1, imagem 2 %32
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: passo 2, imagem 1 %32
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: passo 3, imagem 1 %32
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: passo 4, imagem 1 %32
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: passo 5, imagem 1 %32
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: passo 6, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: passo 7, imagem 1 %32
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: passo 8, imagem 1 %32
    • Replace the old bulb socket with a newly-purchased one.
Conclusão
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
Membro desde: 05/09/20
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 868
