JVC GR-D290U LCD Screen Replacement
Introdução
Ir para o passo 1This is a step-by-step guide to replace an LCD screen in a JVC GR-D290U camera.
O que você precisa
Remove the camera battery. (Not shown.)
Remove the 2 screws connecting the back plate to the camera base.
Put the LCD screen into the silver frame and make sure it lies flat. It should line up with the two white plastic brackets.
Place the black film frame lined up with the white film into the silver frame. Both should be held in place by tabs.
Place the circuit board over the film layers.
Screw in the circuit board to the frame.
Double-check that the LCD screen lies flat in its frame and reinsert the circuit board screw.
Reinsert the circuit board into the slot. Make sure to lock it securely under the tabs.
Reinsert the L-shaped metal piece into its slot. Line it up with the screw hole and the protruding place holder.
Reinsert the 2 screws in the circuit board with the longer screw holding the L-shaped metal piece in place.
Gear Up For Future Repairs
Shop all
