Ir para o conteúdo principal
JBL Clip 3 Battery Replacement
Kyle Montague
Kyle Montague e 8 outros colaboradores
Última atualização em July 31, 2024
35 minutos
Moderado
Introdução
Ir para o passo 1
The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. JBL Clip 3 Battery Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Battery Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Battery Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Battery Replacement: passo 4, imagem 1 %32 JBL Clip 3 Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Battery Replacement, Carabiner Clip: passo 5, imagem 1 %32 JBL Clip 3 Battery Replacement, Carabiner Clip: passo 5, imagem 2 %32
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
    I’ve looked online and can’t find a place to buy the replacement clip. Any tips?
    Elizabeth Morgan - Responder
    Yea, me too. I’m glad I know how to replace it now but where do I get the part???
    Dustin Frank - Responder
    Agree. Showing how to replace a part when no replacment part is available is not at all helpful.
    Ed McAuliffe - Responder
    Has anyone found this part yet? I have 2 of these speakers that need a new clip!
    Paul J. Garay - Responder
    Another option is to remove the clip altogether as it is not fixable. Works fine without it!
    Paul J. Garay -
  6. JBL Clip 3 Battery Replacement, Speaker Battery: passo 6, imagem 1 %32 JBL Clip 3 Battery Replacement, Speaker Battery: passo 6, imagem 2 %32
    • Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Battery Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four screws that secure the motherboard.
  8. JBL Clip 3 Battery Replacement: passo 8, imagem 1 %32
    • Gently lift the motherboard away from the speaker housing.
    • Take care not to damage the soldered connections when lifting the motherboard.
  9. JBL Clip 3 Battery Replacement: passo 9, imagem 1 %32 JBL Clip 3 Battery Replacement: passo 9, imagem 2 %32
    • Use an opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
    • Avoid puncturing or bending the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
    • During reassembly, remember to superglue the new battery back into place.
Conclusão
5 outras pessoas executaram este guia.
Kyle Montague
Membro desde: 03/28/22
262 Reputação
Autoria de 2 guias
Equipe
5Comentários do guia
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - Responder
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee -
Thank you - very helpful guide! Was able to replace my battery with no issues.
JB Zorg - Responder
What can I use to create a new waterproof seal?
Seany Wheels - Responder
Is this the same process as for the JBL Clip 4?
Marc Oliver - Responder
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 55
Últimos 30 dias: 217
Ao todo: 7,980
