JBL Clip 3 Battery Replacement
Introdução
Ir para o passo 1The Clip 3 is IPX7 waterproof and offers up to 10 hours of playtime, powered by a 1000mAh rechargeable Li-ion battery. If the battery is not charging or holding adequate charge, the battery may require replacement.
This guide will show you the step by step process of replacing a speaker battery for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts on this device, because they can be fragile.
O que você precisa
Peças
Ferramentas
Exibir mais…
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Lift the metal carabiner clip from the speaker housing.
I’ve looked online and can’t find a place to buy the replacement clip. Any tips?
Yea, me too. I’m glad I know how to replace it now but where do I get the part???
Agree. Showing how to replace a part when no replacment part is available is not at all helpful.
Has anyone found this part yet? I have 2 of these speakers that need a new clip!
Another option is to remove the clip altogether as it is not fixable. Works fine without it!
Ferramenta utilizada neste passo:Tweezers$4.99
Use a pair of tweezers to lift the two cable connectors from their motherboard sockets.
5 outras pessoas executaram este guia.
5Comentários do guia
What can I use to create a new waterproof seal?
Is this the same process as for the JBL Clip 4?
