Ir para o conteúdo principal
Install Ubuntu 16 on the Pixel
Kevin Fessler
Kevin Fessler e 2 outros colaboradores
Última atualização em May 30, 2019
15 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
This guide will show you how to setup Ubuntu Linux on your Chromebook Pixel without flashing your BIOS.
A word on flashing...
You may choose to remove the Write-Protect screw and tinker with the BIOS or flash it in the future. Note that I am not responsible for any mishaps that may arise from that.
  1. Install Ubuntu 16 on the Pixel, Enable stuff!: passo 1, imagem 1 %32 Install Ubuntu 16 on the Pixel, Enable stuff!: passo 1, imagem 2 %32
    • Enable Developer Mode/Legacy Boot
    • As mentioned before, you don't need to flash your BIOS, we'll just use the stock SeaBIOS.
    • This means you'll have to press "crtl" + "L" on each boot
    • It'll take some time so grab a coffee while you're waiting...
  2. Install Ubuntu 16 on the Pixel, Boot up Ubuntu: passo 2, imagem 1 %32
    • Unlike the Windows installation, you don't need a USB keyboard or mouse to boot the OS
    • Select your USB installer drive on startup
    • You should get the Ubuntu startup screen
  3. Install Ubuntu 16 on the Pixel: passo 3, imagem 1 %32 Install Ubuntu 16 on the Pixel: passo 3, imagem 2 %32
    • I highly recommend you connect to Wi-Fi before you continue to get all the necessary drivers
    • The Wi-Fi card is automatically detected on boot
    • Just step through the installer like you would with any other distro
  4. Install Ubuntu 16 on the Pixel, Reboot: passo 4, imagem 1 %32
    • Remove your installation media and reboot when prompted by Ubuntu
    • On startup, login to your account and setup your hotkeys to enable volume (mute, decrease, increase).
    • Display brightness can be fixed by setting up a custom keymapping:
    • sudo apt-get install xdotool
    • name: Brightness Up command: xdotool key XF86MonBrightnessUp
    • name: Brightness Down command: xdotool key XF86MonBrightnessDown
Conclusão
You're done! If you ever want to get back to ChromeOS just create a recovery drive in your Chrome browser and enable secure boot at the Pixel startup.
Kevin Fessler
Membro desde: 04/16/16
1.830 Reputação
Autoria de 4 guias
2Comentários do guia
Trying to do the brightness key map .I did this sudo apt-get install xdotool.What do I do next i cant seem to find the app xdotool ?
wesley tejeda - Responder
Does it support the light bar in any way or is there a way to enable it
Naru Fox - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 3,618
