Ir para o conteúdo principal
Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement
Timothy Allen
Timothy Allen e um outro colaborador
Última atualização em August 17, 2018
Nenhuma estimativa
Moderado
Em progresso
Guia colaborativo
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, This guide is the second of two guides for replacement of the massage mech in a 2D chair.: passo 1, imagem 1 %32
    • The first guide showed you how to access the mech and mech track. Now we will remove the mech from the chair.
  2. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, Disconnect wires from mech. This can be done at the mech itself following the color chart below.: passo 2, imagem 1 %32
    • Another option is to cut the zip ties on the back mech cable and follow it down the the base of the chair. It can be unplugged from the connector and the mech can be removed with the back cable connected in this way. Make sure you disconnect using the white connectors show in the bottom of the image.
  3. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, The mech will be driven out through the top of the track.: passo 3, imagem 1 %32
    • To do this you need to remove the 4 screws and then lift the top bar out and set aside.
  4. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, If motor is functional, you can use the chair to drive the mech up to the top.: passo 4, imagem 1 %32 Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, If motor is functional, you can use the chair to drive the mech up to the top.: passo 4, imagem 2 %32
    • If motor will drive on its own you can skip steps 5 and go straight to 6.
    • To drive the mech go into a manual massage and then choose point mode. This will let you use the up and down arrows to drive the mech up to the top manually. You may need to remove the upper sensor to allow the mech to move past.
  5. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, Drive the mech out of the top of the track.: passo 5, imagem 1 %32
    • You can use a flat head screwdriver or power screwdriver to manually drive the motor up and out of the chair.
  6. Infinity 2D Massage Chair (Rongtai) Massage Mechanism Replacement, Carefully lift mech out of chair.: passo 6, imagem 1 %32
    • Once the motor is no longer able to move up (reached the top of the track) you can lift the mech up and out.
Conclusão
Timothy Allen
Membro desde: 07/05/18
337 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 412
