Ir para o conteúdo principal
India Mark II Chain Replacement
O que você precisa
  1. India Mark II Chain Replacement, Access Door: passo 1, imagem 1 %32 India Mark II Chain Replacement, Access Door: passo 1, imagem 2 %32
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Chain Replacement: passo 2, imagem 1 %32 India Mark II Chain Replacement: passo 2, imagem 2 %32 India Mark II Chain Replacement: passo 2, imagem 3 %32
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Chain Replacement: passo 3, imagem 1 %32 India Mark II Chain Replacement: passo 3, imagem 2 %32
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark II Chain Replacement, Chain: passo 4, imagem 1 %32 India Mark II Chain Replacement, Chain: passo 4, imagem 2 %32 India Mark II Chain Replacement, Chain: passo 4, imagem 3 %32
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark II Chain Replacement: passo 5, imagem 1 %32 India Mark II Chain Replacement: passo 5, imagem 2 %32 India Mark II Chain Replacement: passo 5, imagem 3 %32
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark II Chain Replacement: passo 6, imagem 1 %32 India Mark II Chain Replacement: passo 6, imagem 2 %32 India Mark II Chain Replacement: passo 6, imagem 3 %32
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark II Chain Replacement: passo 7, imagem 1 %32 India Mark II Chain Replacement: passo 7, imagem 2 %32 India Mark II Chain Replacement: passo 7, imagem 3 %32
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark II Chain Replacement: passo 8, imagem 1 %32 India Mark II Chain Replacement: passo 8, imagem 2 %32 India Mark II Chain Replacement: passo 8, imagem 3 %32
    • Remove the nut from the chain bolt.
  9. India Mark II Chain Replacement: passo 9, imagem 1 %32 India Mark II Chain Replacement: passo 9, imagem 2 %32
    • Remove the washer from the chain bolt.
  10. India Mark II Chain Replacement: passo 10, imagem 1 %32 India Mark II Chain Replacement: passo 10, imagem 2 %32
    • Remove the chain bolt.
  11. India Mark II Chain Replacement: passo 11, imagem 1 %32 India Mark II Chain Replacement: passo 11, imagem 2 %32 India Mark II Chain Replacement: passo 11, imagem 3 %32
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark II Chain Replacement, Head: passo 12, imagem 1 %32 India Mark II Chain Replacement, Head: passo 12, imagem 2 %32 India Mark II Chain Replacement, Head: passo 12, imagem 3 %32
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark II Chain Replacement: passo 13, imagem 1 %32 India Mark II Chain Replacement: passo 13, imagem 2 %32 India Mark II Chain Replacement: passo 13, imagem 3 %32
    • Remove the two bolts and nuts from the handle side.
  14. India Mark II Chain Replacement: passo 14, imagem 1 %32 India Mark II Chain Replacement: passo 14, imagem 2 %32
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark II Chain Replacement: passo 15, imagem 1 %32 India Mark II Chain Replacement: passo 15, imagem 2 %32 India Mark II Chain Replacement: passo 15, imagem 3 %32
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
  16. India Mark II Chain Replacement, Chain: passo 16, imagem 1 %32 India Mark II Chain Replacement, Chain: passo 16, imagem 2 %32
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
  17. India Mark II Chain Replacement: passo 17, imagem 1 %32 India Mark II Chain Replacement: passo 17, imagem 2 %32 India Mark II Chain Replacement: passo 17, imagem 3 %32
    • Lift the head flange up about one foot above the tank.
  18. India Mark II Chain Replacement: passo 18, imagem 1 %32 India Mark II Chain Replacement: passo 18, imagem 2 %32 India Mark II Chain Replacement: passo 18, imagem 3 %32
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
  19. India Mark II Chain Replacement: passo 19, imagem 1 %32 India Mark II Chain Replacement: passo 19, imagem 2 %32
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
  20. India Mark II Chain Replacement: passo 20, imagem 1 %32 India Mark II Chain Replacement: passo 20, imagem 2 %32
    • Lower the head flange.
  21. India Mark II Chain Replacement: passo 21, imagem 1 %32 India Mark II Chain Replacement: passo 21, imagem 2 %32 India Mark II Chain Replacement: passo 21, imagem 3 %32
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
493.536 Reputação
407 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
138 Membros
17.011 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 495
