Ir para o conteúdo principal
Ikea Hektar Lamp Foot Pedal Switch Button Replacement
Jesus Ortiz
Jesus Ortiz e um outro colaborador
Última atualização em June 11, 2024
10 - 20 minutos
Fácil
Guia do aluno destaque
If you have a lamp that operates using a foot pedal lamp switch, it is likely that over time, the button connecting to the spring or the spring itself may become worn or damaged. This can result in the switch to no longer function properly. If this is the case, this guide will show you how to fix the issue by replacing the button with a new one, with easy-to-follow illustrated instructions. This guide demonstrates the repair process on an Ikea Hektar Floor Lamp, but the principles will apply to other foot pedal lamp switches as well.
Before using this guide, make sure your device is unplugged and remains unplugged throughout your repair. Additionally, check for any corrosion around the switch, damage along the cord itself, or burnt cables. These issues may require additional instructions.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: passo 1, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement, Foot Pedal Lamp Switch Button: passo 1, imagem 2 %32
    • Unplug the lamp from the power source.
    • Do not touch the metal prongs sticking out of the connector, only hold by the plastic section of the chord.
    • Find a well-lit area to work in and begin your repair.
  2. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, imagem 2 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 2, imagem 3 %32
    • Flip the lamp switch upside down.
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws from the bottom of the foot pedal while holding the button cap in place.
  3. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 3, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 3, imagem 2 %32
    • Lift the top off of the foot pedal that holds the button in place and put it to the side.
    • Remove the damaged button from the switch and place it to the side.
  4. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 4, imagem 1 %32
    • Briefly inspect the spring and electrical wiring for any visual damage.
    • If no internal damage is visible, continue to the next step.
  5. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 5, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 5, imagem 2 %32
    • Replace the button and top of the foot pedal.
    • The button must be replaced before the cap to be held in place.
  6. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, imagem 2 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 6, imagem 3 %32
    • Flip the pedal switch upside down.
    • Use a Phillips #0 screwdriver to replace the four 6 mm screws on the back while holding the switch together.
  7. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 7, imagem 1 %32 Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 7, imagem 2 %32
    • Inspect the switch for any gaps around the edge.
    • Press down on the button to make sure you hear and/or feel a click.
  8. Ikea Hektar Lamp Foot Pedal Switch Button Replacement: passo 8, imagem 1 %32
    • All done! Now you have a fully functional foot pedal lamp switch.
Conclusão
Jesus Ortiz
Membro desde: 03/15/24
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 58
Duração total: 449
