Ir para o conteúdo principal
Huntington GA41PS-RDS Acoustic Guitar String Replacement
Ruhail Khan
Ruhail Khan e um outro colaborador
Última atualização em May 3, 2022
10 - 20 minutos
Fácil
If for any reason your Huntington GA41PS-RDS acoustic guitar string is broken, use this guide to replace it. The guide will teach you to replace any number of strings. Be careful when handling the strings, the pointed end if poked by can cause bleeding. Before using this guide identify all the strings that need to be replaced.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: passo 1, imagem 1 %32
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, imagem 2 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 2, imagem 3 %32
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 3, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 3, imagem 2 %32
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, imagem 2 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 4, imagem 3 %32
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, imagem 2 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 5, imagem 3 %32
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, imagem 2 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 6, imagem 3 %32
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 7, imagem 1 %32 Huntington GA41PS-RDS Acoustic Guitar String Replacement: passo 7, imagem 2 %32
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
Conclusão
Ruhail Khan
Membro desde: 01/18/22
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 502
