Huawei P8 Lite Earpiece Speaker Replacement
Introdução
Vá para o passo 1This guide will explain how to replace the Earpiece Speaker for the Huawei P8 Lite.
O que você precisa
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Continue by removing the SIM and SD card trays on the side of the device.
Ferramenta utilizada neste passo:Tweezers$3.99
Using the Tweezers, carefully remove the Earpiece Speaker.
Insert the new Earpiece Speaker and follow these steps in reverse order to reassemble the device.
