Ir para o conteúdo principal
How to repair loose threads
Ben Blischke
Ben Blischke e 2 outros colaboradores
Última atualização em April 12, 2025
5 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
Knitted beanies or pullovers are easy to snag during use, resulting in a loose thread loop. But it's not serious, and not hard to fix - follow this guide to find out how!
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to repair loose threads, Prepare the repair: passo 1, imagem 1 %32 How to repair loose threads, Prepare the repair: passo 1, imagem 2 %32 How to repair loose threads, Prepare the repair: passo 1, imagem 3 %32
    • Identify the snag
    • Prepare your needle - for this guide we are using a specialized "snag repair needle" which has a textured end. These are available from most sewing shops.
  2. How to repair loose threads, Pull snag loop through: passo 2, imagem 1 %32 How to repair loose threads, Pull snag loop through: passo 2, imagem 2 %32 How to repair loose threads, Pull snag loop through: passo 2, imagem 3 %32
    • Pass the needle through the bottom of the snag loop.
    • Wrap the thread around the sharp end of the needle.
    • Then, pass the needle through the fabric. The snag loop will also be pulled through by the textured part of the needle. Keep pulling it through, until both the needle and the snag loop are on the inside of the item.
  3. How to repair loose threads, Finished and ready!: passo 3, imagem 1 %32 How to repair loose threads, Finished and ready!: passo 3, imagem 2 %32 How to repair loose threads, Finished and ready!: passo 3, imagem 3 %32
    • Pull tightly on the thread to secure it to the back of the fabric.
    • Then, reposition the fabric appearance on the front, by stretching it to balance the tension.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Uma outra pessoa concluiu este guia.
Ben Blischke
Membro desde: 07/19/23
9.889 Reputação
Autoria de 64 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
24 Membros
Autoria de 164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 43
Ao todo: 526
