Ir para o conteúdo principal
How to repair a "lost" drawstring
Ben Blischke
Ben Blischke e 2 outros colaboradores
Última atualização em October 9, 2024
5 minutos
Muito fácil
Guia colaborativo
The adjustment drawstring on hoodies or shorts can easily get “lost” in the hem tunnel - especially if the knot has come loose during washing. But no problem: it's easy to repair, and doesn't take long at all!
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to repair a "lost" drawstring, Identify the lost drawstring: passo 1, imagem 1 %32 How to repair a "lost" drawstring, Identify the lost drawstring: passo 1, imagem 2 %32 How to repair a "lost" drawstring, Identify the lost drawstring: passo 1, imagem 3 %32
    • One end of the drawstring has got lost inside the hem tunnel and you can't get it back.
  2. How to repair a "lost" drawstring, Pull out the drawstring completely: passo 2, imagem 1 %32 How to repair a "lost" drawstring, Pull out the drawstring completely: passo 2, imagem 2 %32 How to repair a "lost" drawstring, Pull out the drawstring completely: passo 2, imagem 3 %32
    • Pull it on the drawstring and take it out completely.
    • Note: some drawstrings are sewn in place at the back, for safety reasons. If your item has this, simply remove this stitch with small scissors or a seam ripper.
  3. How to repair a "lost" drawstring, Attach the safety pin to the drawstring: passo 3, imagem 1 %32 How to repair a "lost" drawstring, Attach the safety pin to the drawstring: passo 3, imagem 2 %32 How to repair a "lost" drawstring, Attach the safety pin to the drawstring: passo 3, imagem 3 %32
    • Locate the knot at one end of the drawstring; or if there is no knot, make one.
    • Push the safety pin through the knot and re-clasp it.
  4. How to repair a "lost" drawstring, Pull the drawstring through the hem tunnel: passo 4, imagem 1 %32 How to repair a "lost" drawstring, Pull the drawstring through the hem tunnel: passo 4, imagem 2 %32 How to repair a "lost" drawstring, Pull the drawstring through the hem tunnel: passo 4, imagem 3 %32
    • Push the safety pin into one of the holes in the hem tunnel.
    • Push the pin as far as possible, and then hold it in place through the fabric. With the other hand, bunch the hem tunnel towards the first hand.
    • Slide the pin into the bunched hem tunnel, and try to pinch it with the receiving hand. Now, let go of the pin with the first hand, and use this hand to pull the hem tunnel taught.
    • When done correctly, the pin will transfer from one hand to the next hand, slowly moving along the hem tunnel with every bunching-tautening motion.
    • Keep repeating this action until the pin reaches the other end of the hem tunnel. Now, pull out the pin and drawstring together.
  5. How to repair a "lost" drawstring, Rearrange the drawstring: passo 5, imagem 1 %32 How to repair a "lost" drawstring, Rearrange the drawstring: passo 5, imagem 2 %32 How to repair a "lost" drawstring, Rearrange the drawstring: passo 5, imagem 3 %32
    • Fully remove the drawstring end, and pin, from the hem tunnel
    • Remove the safety pin from the drawstring
    • Re-center the drawstring by pulling on each side appropriately
    • Note: if you don't want to re-sew the security stitch at the back, then you're done! ... 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
  6. How to repair a "lost" drawstring, Optional: Re-sew the security stitch: passo 6, imagem 1 %32 How to repair a "lost" drawstring, Optional: Re-sew the security stitch: passo 6, imagem 2 %32 How to repair a "lost" drawstring, Optional: Re-sew the security stitch: passo 6, imagem 3 %32
    • If you wish, the cord drawstring can be re-attached at the back of the item with a security stitch.
    • This can also be a useful step for drawcords without knots, to help them stay in place during washing.
    • Place the item under the sewing machine
    • Make a short straight stitch over the drawcord, to attach it to the fabric. Repeat 1-2 times for extra security and finish with a lock stitch
  7. How to repair a "lost" drawstring, Finished and ready!: passo 7, imagem 1 %32 How to repair a "lost" drawstring, Finished and ready!: passo 7, imagem 2 %32 How to repair a "lost" drawstring, Finished and ready!: passo 7, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 27
Duração total: 367
