Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Philips TV 24PFS5242, use o nosso manual de serviço.
  1. How to open back cover to get access to PCB, Product: passo 1, imagem 1 %32 How to open back cover to get access to PCB, Product: passo 1, imagem 2 %32
    • This is the Philips TV to be disassembled.
    • The stand is actually a loudspeaker and subwoofer system
    • There are no visible screws on the cover other than at the bottom of the stand which does not help to disassemble
  2. How to open back cover to get access to PCB, Back Cover view: passo 2, imagem 1 %32 How to open back cover to get access to PCB, Back Cover view: passo 2, imagem 2 %32 How to open back cover to get access to PCB, Back Cover view: passo 2, imagem 3 %32
    • The (large) aluminum clip is attached to the back cover and the subwoofer preventing the back cover to come off
    • It needs some force to move, push the aluminum clip towards the subwoofer stand in order to release the two latches holding the clip to the back cover
  3. How to open back cover to get access to PCB, Back Cover removed: passo 3, imagem 1 %32
    • Remvoved back cover with the two holes for the clip latches
    • The back cover itself is just as usual "clicked in" the frame
  4. How to open back cover to get access to PCB, PCB: passo 4, imagem 1 %32
    • Back cover removed giving access to the power supply and main board
    • The subwoofer can also be detached from here
Juergen Klute
Membro desde: 02/02/14
645 Reputação
Autoria de 2 guias
Equipe
JKL Consulting Membro de JKL Consulting
Business
1 Membro
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 245
