Ir para o conteúdo principal
How to fix a Backpack with a Broken Mesh
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em January 8, 2025
5 minutos
Muito fácil
Guia colaborativo
Got a broken mesh on your backpack? No worries! A damaged mesh can mess with your backpack’s look and usefulness, but we’ve got you covered.
If the whole mesh is fully deteriorated, sometimes the best fix is to simply remove it entirely. This can stop any more tearing and give you a cleaner, sturdier solution. Ready to get your backpack back in action?
O que você precisa
Ferramentas
  1. How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 3 %32
    • Identify the defective area and assess how large the damage is.
  2. How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 3 %32
    • Use a pair of scissors to cut the mesh.
    • Make sure you start cutting at the edge of the seam.
    • The cut should be "clean", without leaving any mesh parts behind.
  3. How to fix a Backpack with a Broken Mesh, Clean the area: passo 3, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Clean the area: passo 3, imagem 2 %32
    • Removed the mesh completely and set aside.
  4. How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 32
Duração total: 126
