Ir para o conteúdo principal
How to fix a Backpack with a Broken Mesh
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em April 18, 2025
5 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
Got a broken mesh on your backpack? No worries! A damaged mesh can mess with your backpack’s look and usefulness, but we’ve got you covered.
If the whole mesh is fully deteriorated, sometimes the best fix is to simply remove it entirely. This can stop any more tearing and give you a cleaner, sturdier solution. Ready to get your backpack back in action?
➡️Before you get started, please check the safety disclaimer at the bottom of the page.
  1. How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Identify the repair area: passo 1, imagem 3 %32
    • Identify the defective area and assess how large the damage is.
  2. How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Cut the mesh: passo 2, imagem 3 %32
    • Use a pair of scissors to cut the mesh.
    • Make sure you start cutting at the edge of the seam.
    • The cut should be "clean", without leaving any mesh parts behind.
  3. How to fix a Backpack with a Broken Mesh, Clean the area: passo 3, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Clean the area: passo 3, imagem 2 %32
    • Removed the mesh completely and set aside.
  4. How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 1 %32 How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 2 %32 How to fix a Backpack with a Broken Mesh, Finished and ready!: passo 4, imagem 3 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro desde: 07/19/23
9.886 Reputação
Autoria de 64 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
24 Membros
Autoria de 164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 51
Ao todo: 194
