Ir para o conteúdo principal
How to clean a rusting Microwave
Tristan Hill
Tristan Hill e 3 outros colaboradores
Última atualização em December 31, 2023
1 - 2 dias
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
Rust can appear after a few years inside a microwave, particularly to the area the tray rollers run over. This guide covers cleaning and applying touch up paint to the affected areas.
What paint do I use inside the microwave oven?
The solution is a paint that resists high temperatures and at the same time is suitable for food use and free of toxics.
O que você precisa
  1. How to clean a rusting Microwave, Prepare the surface: passo 1, imagem 1 %32
    • Unplug the microwave oven.
    • Clean the surface of all grease residue with alcohol or acetone.
    What about clear nail varnish..no colour being the aim
    fretzopenmic - Responder
  2. How to clean a rusting Microwave, Remove the rust: passo 2, imagem 1 %32
    • Remove the glass tray and roller ring
    • Remove the stuck rust with steel wool.
    • Wipe away any debris with a dry cloth
  3. How to clean a rusting Microwave, Apply the paint: passo 3, imagem 1 %32
    • Shake the tin
    • Apply a thin coat with the brush
    • Give the paint at least 6 hours to dry
    • Apply 1 or 2 more coats as appriopriate
    How do you repair the hole?
    Sharon Kirwan - Responder
    Existe tinta própria para micro-ondas
    Dane Faria - Responder
  4. How to clean a rusting Microwave, Replace tray: passo 4, imagem 1 %32
    • Allow time for the paint coatings to dry properly, ideally overnight with the door open.
    • Replace roller ring and tray. Plug your oven to the power outlet.
    • You are now ready to use your microwave oven again!
    Como se llama la pintura ?
    Cristobal - Responder
    Nombre de la pintura para el microondas
Linha de Chegada
20 outras pessoas executaram este guia.
Tristan Hill
Membro desde: 08/31/15
579 Reputação
Autoria de 1 guia
4Comentários do guia
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
wgcormier - Responder
Thank you for the information.
Marci B Jeffcoats - Responder
Where do I buy the special paint
Diane Sauchuk - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 44
Últimos 30 dias: 229
Ao todo: 61,994
