How to clean a rusting Microwave
Introdução
Ir para o passo 1Rust can appear after a few years inside a microwave, particularly to the area the tray rollers run over. This guide covers cleaning and applying touch up paint to the affected areas.
What paint do I use inside the microwave oven?
The solution is a paint that resists high temperatures and at the same time is suitable for food use and free of toxics.
O que você precisa
Peças
Ferramentas
Exibir mais…
Unplug the microwave oven.
Clean the surface of all grease residue with alcohol or acetone.
Remove the glass tray and roller ring
Remove the stuck rust with steel wool.
Wipe away any debris with a dry cloth
Shake the tin
Apply a thin coat with the brush
Give the paint at least 6 hours to dry
Apply 1 or 2 more coats as appriopriate
Allow time for the paint coatings to dry properly, ideally overnight with the door open.
Replace roller ring and tray. Plug your oven to the power outlet.
You are now ready to use your microwave oven again!
20 outras pessoas executaram este guia.
4 comentários
Thanks so much!!! I got a small microwave from a rental unit ( it was rusted ans I thought i would be excellent for my fishing cabin ( in the wine country ). I WANTED TO USE EPOXY OR ENGINE PAINT!!! The mention set so many individuals at multiple sites off to saying things about toxic fumes and other ridiculous things. there’s even a special paint Amazon sells!!! https://www.google.com/search?client=fir...
So Easy thanks
Thank you for the information.
Where do I buy the special paint
