Ir para o conteúdo principal
How to change the grips on a golf club
Esteban Ortega
Esteban Ortega e 2 outros colaboradores
Última atualização em August 4, 2023
10 - 15 minutos
Difícil
Are the grips on your golf clubs getting old? Are your grips not providing you with the grip you need to maximize your performance on the course? This guide will inform you step-by-step on how to change those old grips for new grips.
  1. How to change the grips on a golf club, Grip: passo 1, imagem 1 %32 How to change the grips on a golf club, Grip: passo 1, imagem 2 %32
    • Tighten golf club on vice clamp. Align the golf club so that the club face is vertical.
    • Note: Make sure you place container underneath the grip to catch excess mineral spray in later steps.
  2. How to change the grips on a golf club: passo 2, imagem 1 %32 How to change the grips on a golf club: passo 2, imagem 2 %32
    • With the xacto knife cut the old grip off of the club.
    • Remove grip from club.
  3. How to change the grips on a golf club: passo 3, imagem 1 %32 How to change the grips on a golf club: passo 3, imagem 2 %32
    • Measure the amount of double-sided tape necessary to cover the area of your grip.
    • Place the tape on the club so that it is centered and an extra inch comes off the end of the club.
  4. How to change the grips on a golf club: passo 4, imagem 1 %32 How to change the grips on a golf club: passo 4, imagem 2 %32
    • Squirt mineral spirits on the tape.
    • Make sure you drench the tape in mineral spirits.
    • Note: it is safe to get mineral spirits on your skin, it is non-toxic.
  5. How to change the grips on a golf club: passo 5, imagem 1 %32 How to change the grips on a golf club: passo 5, imagem 2 %32 How to change the grips on a golf club: passo 5, imagem 3 %32
    • While the tape still has mineral spray on it, quickly slide the grip all the way down.
  6. How to change the grips on a golf club: passo 6, imagem 1 %32
    • Wait 1-2 hours for the mineral spray to dry.
Conclusão
Uma outra pessoa concluiu este guia.
Esteban Ortega
Membro desde: 04/09/15
147 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-2, Green Spring 2015 Membro de Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
Membros da 4
Autoria de 4 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,173
