Ir para o conteúdo principal
How to boot Intel Desktop Board D945PSN in Maintenance Mode
Sebastian
Sebastian e 5 outros colaboradores
Última atualização em July 26, 2024
5 - 10 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
After spending half the day looking for how to reset CMOS, nothing worked.
Issue symptoms - after setting RAM mode to aggressive, system went into ram failure (3 long beeps with no possibility to enter setup). Nothing worked - tried removing the battery, shorting battery pins, nothing happened, same 3 long beeps.
  • So, near the battery there is the CMOS Jumper - 3 pins, last two of them from left to right are connected with a jumper.
  • Turn off the power source or unplugg it, take the jumper out and place it on the first two pins (from left to right).
  • Then plug the computer to power and start the system. It will take you to maintenance mode where you can change the faulty settings (in my case RAM management).
  • After you save the settings, bios will let you notice that you need to put the pins in the normal position in order to boot.
  • Power off, unplug the power, put the Jumper back, and you're set. You can safely turn on.
O que você precisa
Ferramentas
    • The beeping RAM Failure wouldn't let me boot since mainboard needs at least 128 mb of ram installed and with the "Agressive" ram setting it wouldn't see any of the RAM disks.
    • It beeped for hours without any real convetional (short battery pins or remove battery) fixes
  1. How to boot Intel Desktop Board D945PSN in Maintenance Mode, Locate CMOS Jumper and follow the instructions (adnotations on second pic): passo 2, imagem 1 %32 How to boot Intel Desktop Board D945PSN in Maintenance Mode, Locate CMOS Jumper and follow the instructions (adnotations on second pic): passo 2, imagem 2 %32
    • Switch jumper from normal position to "configure position" and start the system - it will go to maintenance mode.
  2. How to boot Intel Desktop Board D945PSN in Maintenance Mode: passo 3, imagem 1 %32 How to boot Intel Desktop Board D945PSN in Maintenance Mode: passo 3, imagem 2 %32
    • After you change the faulty settings, turn off and reinstall the jumper in Normal mode position as the Bios mentions.
    • After that see if the settings helped (i had to switch from aggressive mode to Automatic Ram management) and computer should boot up normally.
Conclusão
That's the guide on how to reset CMOS or enter Maintenance mode on Intel mainboard D945PSN
17 outras pessoas executaram este guia.
Sebastian
Membro desde: 01/29/15
672 Reputação
Autoria de 1 guia
4Comentários do guia
Please I have a problem with an Intel desktop motherbord and the motherboard gives a sign that light is on the mainboard but I notice that it only given a light but not display on the screen
kenny - Responder
I don't know how to hook this dell desktop... An I pulled out a wire on the motherboard
D ON THA BANG-EL TnD Pro. - Responder
I keep getting that black screen (turn off and reinstall the jumper) despite having it in normal mode
Tonhs - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 175
Ao todo: 14,949
