How to align Razor A steering
Introdução
Ir para o passo 1Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
O que você precisa
Ferramentas
Locate the collar clamp near the base of the steering column.
Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
17 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all4Comentários do guia
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
at this part it would easily loosen for a few seconds then get hard again can you update this and mention that please if its normal
Caleb Rigby (Awesomegamez) - Responder
After loosening and re-aligning make sure to tighten it back up really tight so the problem will be avoided for a while. Eventually you will probably have to do this again after using the scooter a lot.
Nolan Proulx - Responder
