Ir para o conteúdo principal
How to align Razor A steering
Jordyn
Jordyn e 3 outros colaboradores
Última atualização em 3 de ago de 2023
3 - 5 minutos
Fácil
Introdução
Ir para o passo 1
Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
O que você precisa
Ferramentas
  1. How to align Razor A steering, How to align Razor A steering: passo 1, imagem 1 %32 How to align Razor A steering, How to align Razor A steering: passo 1, imagem 2 %32 How to align Razor A steering, How to align Razor A steering: passo 1, imagem 3 %32
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
    at this part it would easily loosen for a few seconds then get hard again can you update this and mention that please if its normal
    Caleb Rigby (Awesomegamez) - Responder
    After loosening and re-aligning make sure to tighten it back up really tight so the problem will be avoided for a while. Eventually you will probably have to do this again after using the scooter a lot.
    Nolan Proulx - Responder
  2. How to align Razor A steering: passo 2, imagem 1 %32 How to align Razor A steering: passo 2, imagem 2 %32
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Linha de Chegada
17 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Jordyn
Membro desde: 10/09/12
565 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-13, Amido Fall 2012 Membro de Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membros
Autoria de 10 guias
4Comentários do guia
This is so unhelpful.
Linh Tran - Responder
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Responder
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Responder
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 28
Últimos 30 dias: 101
Ao todo: 31,097
