Ir para o conteúdo principal
How to Wire a RJ-45 KeyStone Jack
Samuel Lynch
Samuel Lynch e um outro colaborador
Última atualização em March 11, 2023
10 - 15 minutos
Fácil
Guia colaborativo
Introdução
Ir para o passo 1
This is a simple guide to wiring a keystone jack for use in house and business applications.
  1. How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, imagem 1 %32 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, imagem 2 %32 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: passo 1, imagem 3 %32
  2. How to Wire a RJ-45 KeyStone Jack: passo 2, imagem 1 %32 How to Wire a RJ-45 KeyStone Jack: passo 2, imagem 2 %32 How to Wire a RJ-45 KeyStone Jack: passo 2, imagem 3 %32
    • Use your wire stripper to cut the outer sheath
    • Do Not Rotate more than 3-4 times as it will cut the wires underneath.
    • when the length of exposed wires are at a decent length (a little less than a thumbs length) separate the wires by color.
  3. How to Wire a RJ-45 KeyStone Jack: passo 3, imagem 1 %32 How to Wire a RJ-45 KeyStone Jack: passo 3, imagem 2 %32 How to Wire a RJ-45 KeyStone Jack: passo 3, imagem 3 %32
    • on the keystone jack you will see colors. line the wires up to the corresponding colors (white blue - blue, white orange - orange, etc.)
    • use the punchdown tool with the longer side of the blade on the outside to punch the wires in and it will cut off the excess.
    • repeat for each color
  4. How to Wire a RJ-45 KeyStone Jack: passo 4, imagem 1 %32 How to Wire a RJ-45 KeyStone Jack: passo 4, imagem 2 %32 How to Wire a RJ-45 KeyStone Jack: passo 4, imagem 3 %32
    • open up your mounting box
    • there should be a frame for your jack to snap into
  5. How to Wire a RJ-45 KeyStone Jack: passo 5, imagem 1 %32 How to Wire a RJ-45 KeyStone Jack: passo 5, imagem 2 %32
    • place the jack into the mounting box, there should be places for zip ties to hold the cable in place
    • place the cover on top and you are done with your cable!
    • test the line using a cable tester.
Conclusão
Make Sure to test with a cable tester
6 outras pessoas executaram este guia.
Samuel Lynch
Membro desde: 04/24/18
293 Reputação
Autoria de 1 guia
Equipe
Sams TechRepair Membro de Sams TechRepair
Business
1 Membro
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 44
Últimos 30 dias: 250
Ao todo: 21,117
