Ir para o conteúdo principal
How to Winterize Sprinkler System
Corneliu Fabian
Corneliu Fabian e um outro colaborador
Última atualização em December 13, 2019
35 minutos
Moderado
Introdução
Ir para o passo 1
Winter is around the corner, which means that it’s getting cold outside, putting your sprinkler system lines to risk of freezing. When water freezes, it expands. This hydro-expansion can cause fittings, sprinklers, valves, pumps, pipes and other parts of irrigation systems to burst and break. Draining your system of all water is the only way to ensure that it will still be in working order when spring arrives. Luckily, there’s a way that you can take care of that and blow the water out of the system so it doesn’t freeze. This is an easy and fast guide showing you exactly what to do to get your sprinkler system ready for the winter.
  1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: passo 1, imagem 1 %32 How to Winterize Sprinkler System, How to Winterize Sprinkler System: passo 1, imagem 2 %32
    • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
  2. How to Winterize Sprinkler System: passo 2, imagem 1 %32
    • Obtain an air compressor. (you can rent one from the local Home Depot)
  3. How to Winterize Sprinkler System: passo 3, imagem 1 %32 How to Winterize Sprinkler System: passo 3, imagem 2 %32 How to Winterize Sprinkler System: passo 3, imagem 3 %32
    • Connect a hose to the compressor, and one to the water line (in basement).
  4. How to Winterize Sprinkler System: passo 4, imagem 1 %32
    • Turn the compressor on.
  5. How to Winterize Sprinkler System: passo 5, imagem 1 %32
    • Start manually turning on each station of the system one by one.
  6. How to Winterize Sprinkler System: passo 6, imagem 1 %32
    • Let the air blow the water out for about 2 minutes per station.
  7. How to Winterize Sprinkler System: passo 7, imagem 1 %32 How to Winterize Sprinkler System: passo 7, imagem 2 %32 How to Winterize Sprinkler System: passo 7, imagem 3 %32
    • Unplug the hose from the compressor and the water line.
  8. How to Winterize Sprinkler System: passo 8, imagem 1 %32 How to Winterize Sprinkler System: passo 8, imagem 2 %32
    • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
Conclusão
Corneliu Fabian
Membro desde: 10/07/19
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 716
