Ir para o conteúdo principal
How to Unclog a Toilet with an Auger
Dante
Dante e um outro colaborador
Última atualização em May 7, 2024
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
In the event a plunger or a liquid solution fails to unclog a toilet, a $20 toilet auger can help you avoid a $150-plus plumber visit. A toilet auger, also known as a plumber's snake, is a specialized tool designed to navigate through the twists and turns of a toilet's plumbing system to dislodge and remove obstructions. Toilet augers are also used by professional plumbers. In this comprehensive guide, we will walk you through the step-by-step process of using a toilet auger to effectively and safely unclog a toilet.
  1. How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: passo 1, imagem 1 %32 How to Unclog a Toilet with an Auger, How to Unclog a Toilet with an Auger: passo 1, imagem 2 %32
    • Turn the auger's handle counterclockwise and pull it towards you to retract the snake.
  2. How to Unclog a Toilet with an Auger: passo 2, imagem 1 %32 How to Unclog a Toilet with an Auger: passo 2, imagem 2 %32
    • Place the auger directly into the toilet bowl.
    • The end of the auger can scratch the toilet bowl, so use caution.
  3. How to Unclog a Toilet with an Auger: passo 3, imagem 1 %32
    • Turn the handle clockwise to push the auger down the drain.
    • Stop when the handle gets stiff.
  4. How to Unclog a Toilet with an Auger: passo 4, imagem 1 %32 How to Unclog a Toilet with an Auger: passo 4, imagem 2 %32
    • Turn the handle counterclockwise while pulling it towards you to retract the auger.
    • Remove the auger from the toilet and dispose of anything caught by the metal.
  5. How to Unclog a Toilet with an Auger: passo 5, imagem 1 %32
    • Flush the toilet to see if the water resets to a normal level.
    • Be prepared to push and retract the auger multiple times to clear the clog.
  6. How to Unclog a Toilet with an Auger: passo 6, imagem 1 %32
    • Once the toilet is unclogged, place the auger in a towel to dry.
Linha de Chegada
Dante
Membro desde: 01/16/24
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 164
