Ir para o conteúdo principal
How to Unclog a Toilet Drainpipe
Chen Liang
Chen Liang e um outro colaborador
Última atualização em December 29, 2022
30 minutos
Moderada
This guide is for clearing a toilet drainpipe that has been clogged by a toy or other large object.
A clogged pipe can happen frequently, especially when a family has kids. Kids may drop toys in the toilet bowl and flush them by accident. If this happens, do not worry. This guide will help parents detach a toilet bowl and remove stuck objects.
The tools are common household items and the process doesn’t take long. One thing the fixer needs to notice is that the toilet bowl in this guide is a one-piece, which means there is no need to remove the water tank from the toilet bowl. If you are using a two-piece toilet, you need to remove water tank first, and then remove the bowl.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Unclog a Toilet Drainpipe, How to Unclog a Toilet Drainpipe: passo 1, imagem 1 %32
    • Turn off the water supply.
    • The switch of water supply may locate differently depends on different pipe structure. Find it either left or right of toilet bowl on the floor.
  2. How to Unclog a Toilet Drainpipe: passo 2, imagem 1 %32
    • Flush the toilet in order to empty the water tank and the bowl.
  3. How to Unclog a Toilet Drainpipe: passo 3, imagem 1 %32
    • Use a sponge or paper towel to clean the water left in the water tank.
    • Make sure you wear the gloves.
  4. How to Unclog a Toilet Drainpipe: passo 4, imagem 1 %32
    • Remove the water supply pipe from the toilet bowl.
  5. How to Unclog a Toilet Drainpipe: passo 5, imagem 1 %32 How to Unclog a Toilet Drainpipe: passo 5, imagem 2 %32 How to Unclog a Toilet Drainpipe: passo 5, imagem 3 %32
    • Find the floor bolts and remove the decorative cap off the bolts.
    • Remove the bolts with a wrench.
  6. How to Unclog a Toilet Drainpipe: passo 6, imagem 1 %32
    • After removing the floor bolts, wiggle the bowl and remove it.
    • Remove anything that may be stuck in the pipe.
Conclusão
Uma outra pessoa concluiu este guia.
Chen Liang
Membro desde: 07/08/20
160 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,431
