Ir para o conteúdo principal
How to Unclog a Sink
O que você precisa
  1. How to Unclog a Sink, How to Unclog a Sink: passo 1, imagem 1 %32 How to Unclog a Sink, How to Unclog a Sink: passo 1, imagem 2 %32 How to Unclog a Sink, How to Unclog a Sink: passo 1, imagem 3 %32
    • Begin by filling the sink halfway full with water.
    • Pump the plunger rapidly for 30 seconds.
    • Do NOT break seal between plunger and drain.
    • Repeat this process 4 to 6 times.
    • Wait 20 min before proceeding to the next step. This will allow some debris to flow down the pipes.
  2. How to Unclog a Sink: passo 2, imagem 1 %32 How to Unclog a Sink: passo 2, imagem 2 %32
    • Place a bucket below the P-trap .
    • The curved white pipe is called the P-trap.
    • These next few steps may get a bit messy. Proceed with caution.
  3. How to Unclog a Sink: passo 3, imagem 1 %32 How to Unclog a Sink: passo 3, imagem 2 %32 How to Unclog a Sink: passo 3, imagem 3 %32
    • Carefully untwist slip nuts by hand.
    • If you are unable to remove by hand, use a slip joint plier to remove the slip nuts.
    • The nuts at the ends of the P-trap are called slip nuts.
  4. How to Unclog a Sink: passo 4, imagem 1 %32 How to Unclog a Sink: passo 4, imagem 2 %32 How to Unclog a Sink: passo 4, imagem 3 %32
    • Use a small wire brush to clean the P-trap.
    • You may want to clean the connecting pipes with the wire brush as well.
  5. How to Unclog a Sink: passo 5, imagem 1 %32 How to Unclog a Sink: passo 5, imagem 2 %32 How to Unclog a Sink: passo 5, imagem 3 %32
    • Carefully rinse the P-trap with hot water.
    • Do NOT rinse the P-trap in the sink you are working on because there is no connecting pipe to catch the water.
  6. How to Unclog a Sink: passo 6, imagem 1 %32 How to Unclog a Sink: passo 6, imagem 2 %32 How to Unclog a Sink: passo 6, imagem 3 %32
    • Reattach the P-trap.
  7. How to Unclog a Sink: passo 7, imagem 1 %32 How to Unclog a Sink: passo 7, imagem 2 %32 How to Unclog a Sink: passo 7, imagem 3 %32
    • Pour 1/2 cup of baking soda down the drain.
    • Pour 1/2 cup of distilled white vinegar down the drain.
    • Quickly cover the drain with a drain stopper.
    • This keeps the reaction in the pipes.
  8. How to Unclog a Sink: passo 8, imagem 1 %32 How to Unclog a Sink: passo 8, imagem 2 %32
    • As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
    • Cover again with a drain stopper.
    • Let the sink sit for 20 min.
  9. How to Unclog a Sink: passo 9, imagem 1 %32 How to Unclog a Sink: passo 9, imagem 2 %32 How to Unclog a Sink: passo 9, imagem 3 %32
    • Boil 1 gallon of water with a boiler.
    • The boiler will get hot. Handle with care.
    • Pour the boiling water down the sink to flush out any remaining debris.
Linha de Chegada
5 outras pessoas executaram este guia.
Daniel Sanchez
Membro desde: 09/29/15
299 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-2, Green Fall 2015 Membro de Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 3,735
