Ir para o conteúdo principal
How to Unclog a Drain Hose
Mohammad Sameer
Mohammad Sameer e um outro colaborador
Última atualização em June 7, 2021
20 - 25 minutos
Moderado
Precisa de melhores imagens
Precisa de mais images
Introdução
Ir para o passo 1
Washing machines are essential for every individual, but sometimes they can have problems such as clogged drain which will cause the washing machine to drain slowly. This is due to leftover materials such as soap residue, dryer lint, grease, and dirt that come from your clothes. To fix this, you need to clean the drainage pipe manually. This can be done with the help of a tool such as a snake drain. With little time and effort, you can fix your clogged washing machine. This guide will provide steps needed to fix the problem and help gain an essential skill.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Unclog a Drain Hose, How to Unclog a Drain Hose: passo 1, imagem 1 %32
    • Turn off the washing machine.
  2. How to Unclog a Drain Hose: passo 2, imagem 1 %32
    • Adjust the washing machine to make enough space to walk in and clean the drain hose.
  3. How to Unclog a Drain Hose: passo 3, imagem 1 %32
    • Wear proper safety gloves and remove the drain hose carefully.
  4. How to Unclog a Drain Hose: passo 4, imagem 1 %32
    • Pour hot water to help in the process of cleaning the clogged drain.
  5. How to Unclog a Drain Hose: passo 5, imagem 1 %32
    • Use a snake drain and rotate the handle to unclog all the debris.
  6. How to Unclog a Drain Hose: passo 6, imagem 1 %32
    • carefully attach the drain hose back.
Conclusão
Mohammad Sameer
Membro desde: 01/22/21
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 417
