How to Troubleshoot Generic 1A USB Car Charger
Introdução
Ir para o passo 1If you have a device that will not charge in the car, then this guide is designed to help you discover if the problem is with the adapter or with the device. The guide is not difficult, but you will be working with live 12 volt and 5 volt electricity, and requires knowledge of how your multimeter works.
O que você precisa
Peças
Ferramentas
Exibir mais…
Insert the USB Micro end into the breakout, and insert the adapter into a power source, set for 12V (or automatic if in vehicle).
3 outras pessoas executaram este guia.
