Introdução
Active End: The end of the tie that will be used to tie the knot. This can be either the wide end or narrow end of the tie depending on the tie knot.
Shirt Collar: A band of material around the neck of a shirt that can either be folded or unfolded.
Neck Loop: The loop of the tie that goes around the collar.
The Trinity: A more complicated knot for people with more experience. This knot ends with a shorter, wider end, better suited for people wearing suits or vest.
Ferramentas
Nenhuma ferramenta especificada.
Peças
Take the active end and it cross over the wide end, so it is pointing to the left.
Tighten the neck knot by holding the knot and pulling on the narrow end of the tie away from you.
Congratulations! You've successful tied the Trinity knot!
2 outras pessoas concluíram este guia.
