Ir para o conteúdo principal
How to Solder Components onto the Beats Pill 1.0
Paul Haas
Paul Haas e 6 outros colaboradores
Última atualização em February 19, 2016
15 - 25 minutos
Difícil
Fotos de ação
Melhor Introdução
O que você precisa
Ferramentas
Exibir mais…
  1. How to Solder Components onto the Beats Pill 1.0, How to Solder Components onto the Beats Pill 1.0: passo 1, imagem 1 %32
    • Plug in the soldering iron and let it reach optimum temperature.
    • The soldering iron is very hot. Please do not touch the the tip of the iron when it is plugged in or until the iron cools.
    • Make sure it is plugged into a 150W outlet (common household wall outlet). Check the device for damages and impurities on the tip such as plastic or grease. Please make sure the iron is not in any contact with potentially flammable items and clean the tip if the soldering iron has been heavily used.
  2. How to Solder Components onto the Beats Pill 1.0: passo 2, imagem 1 %32
    • Check that the connection between the wire and the device has good contact. Prior to beginning the soldering process make sure the the conjoining connections between the wire and the device are properly wound together.
  3. How to Solder Components onto the Beats Pill 1.0: passo 3, imagem 1 %32
    • Apply solder agent to iron until the tip of the iron is coated in the metallic agent. This agent needs to be heated to just under 400 Celsius. Use precaution not to drop hot soldering on you.
  4. How to Solder Components onto the Beats Pill 1.0: passo 4, imagem 1 %32
    • Touch the soldering iron to the connection and evenly apply a layer of solder to connect and create a good a connection between the wire and the device.
  5. How to Solder Components onto the Beats Pill 1.0: passo 5, imagem 1 %32
    • Finally wait until the solder cools before re-assembly. It should cool within seconds of application.
Conclusão
4 outras pessoas executaram este guia.
Paul Haas
Membro desde: 01/13/15
778 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 3-2, Hickman Winter 2015 Membro de USF Tampa, Team 3-2, Hickman Winter 2015
USFT-HICKMAN-W15S3G2
4 Membros
Autoria de 6 guias
1Comentário do guia
As a developer with Google's platform to enhance the Google Assistant A.I. with better commands, your website recognized my online profile and asked if I would provide better pictures for just soldering process and I would be honored as I'm currently performing this repair now, stay tuned!
Jamie J. - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 32
Ao todo: 5,521
