Ir para o conteúdo principal
How to Sew a Buttonhole by Hand
Michelle Macias
Michelle Macias e 2 outros colaboradores
Última atualização em March 26, 2025
1 hora
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
Knowing how to sew a buttonhole by hand is a handy skill to have if you don't own a sewing machine and don't want to pay a tailor. If you can sew a basic straight stitch, you can make a buttonhole. Pull that old favorite shirt out of the discard bag and give it a new life. Your small but mighty needle will help you keep the clothes in your closet instead of in the landfill.
  1. How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: passo 1, imagem 1 %32 How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: passo 1, imagem 2 %32
    • Place your button where you want the buttonhole.
    • Use a chalk marker or washable fabric marker to make a vertical line just to the right of the button.
    • Use your marker to make a vertical line just to the left of the button.
  2. How to Sew a Buttonhole by Hand: passo 2, imagem 1 %32
    • Use your marker to make a horizontal line that connects the two vertical lines.
  3. How to Sew a Buttonhole by Hand: passo 3, imagem 1 %32 How to Sew a Buttonhole by Hand: passo 3, imagem 2 %32 How to Sew a Buttonhole by Hand: passo 3, imagem 3 %32
    • Sew your first stitch from the top to the bottom of the vertical chalk line on the left.
    • Continue by sewing a running line of small stitches underneath the horizontal chalk line, up the right side, then above the horizontal line.
    • This is the outline for the buttonhole.
  4. How to Sew a Buttonhole by Hand: passo 4, imagem 1 %32 How to Sew a Buttonhole by Hand: passo 4, imagem 2 %32 How to Sew a Buttonhole by Hand: passo 4, imagem 3 %32
    • Use a seam ripper to poke a hole in the fabric that is large enough for your scissors.
    • Use your scissors to cut a slit along the horizontal chalk line in the middle of your stitched outline.
  5. How to Sew a Buttonhole by Hand: passo 5, imagem 1 %32
    • Slide your button into the slit to make sure it's large enough.
  6. How to Sew a Buttonhole by Hand: passo 6, imagem 1 %32 How to Sew a Buttonhole by Hand: passo 6, imagem 2 %32 How to Sew a Buttonhole by Hand: passo 6, imagem 3 %32
    • Bring your threaded needle up through the slit.
    • Push the needle back down through the fabric just to the outside of your first outline stitch.
    • Bring the needle back up through the slit and continue making a row of small, tight, vertical stitches along the bottom edge of the slit.
  7. How to Sew a Buttonhole by Hand: passo 7, imagem 1 %32
    • When you get to the right edge of the slit, continue by making a small row of horizontal stitches around that end of the buttonhole.
  8. How to Sew a Buttonhole by Hand: passo 8, imagem 1 %32 How to Sew a Buttonhole by Hand: passo 8, imagem 2 %32
    • Working from right to left, continue sewing small, tight, vertical stitches along the top side of the buttonhole slit.
    • When you get to the left edge, make a row of small horizontal stitches around that end, until you arrive back where you began.
    • Push your needle through to the back and tie it off with a knot.
  9. How to Sew a Buttonhole by Hand: passo 9, imagem 1 %32
    • Test your new buttonhole and enjoy!
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 79
Últimos 30 dias: 293
Ao todo: 1,878
