How to Secure a Hook and Eye Fastener Properly
Introdução
Ir para o passo 1As we continue to wear our clothing, it may start to lose the durability it once had. Adding a hook and eyes on certain clothing such as a dress, would make the clothing item last longer. This guide would show step by step how to thread a sewing needle and how to properly sew on hook and eyes to a clothing item. By using this guide, it would prolong the life of the clothing item and reduce the amount of clothing someone may throw out.
O que você precisa
Ferramentas
Exibir mais…
Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
Then thread the two ends through the eye of the needle.
Now hold the other eye of the hook in place.
The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
After that push, the needle through that loop and pull which create a small knot.
Now repeat this stitch two more times.
