Ir para o conteúdo principal
How to Reupholster a Bench Cushion
Xochitl Vara
Xochitl Vara e um outro colaborador
Última atualização em June 7, 2022
3 horas
Moderado
Faltando Passos
Introdução
Ir para o passo 1
This guide will show you how to reupholster the fabric on a bench cushion. Whether your bench is dirty or just out of date, this guide will help bring your bench back to looking new.
Before using this guide, check to see if the base is screwed onto the frame of the bench. If this is the case, you will need a screwdriver to remove the screws. This guide demonstrates a bench base that is not screwed onto the frame.
Also, if working outdoors, lay a layer of protection on the ground to keep the new fabric from getting dirty. I used an 8ft x 8ft sheet of material.
Step 6 requires stapling the fabric onto the base with a staple gun. Step 5 shows how to remove the lock and how to insert new staples.
Before starting the guide, make sure to gather your tools and materials beforehand, as your bench may be different and need additional tools.
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 1 %32 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 2 %32 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: passo 1, imagem 3 %32
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: passo 2, imagem 1 %32 How to Reupholster a Bench Cushion: passo 2, imagem 2 %32 How to Reupholster a Bench Cushion: passo 2, imagem 3 %32
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: passo 3, imagem 1 %32 How to Reupholster a Bench Cushion: passo 3, imagem 2 %32 How to Reupholster a Bench Cushion: passo 3, imagem 3 %32
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: passo 4, imagem 1 %32 How to Reupholster a Bench Cushion: passo 4, imagem 2 %32 How to Reupholster a Bench Cushion: passo 4, imagem 3 %32
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: passo 5, imagem 1 %32 How to Reupholster a Bench Cushion: passo 5, imagem 2 %32 How to Reupholster a Bench Cushion: passo 5, imagem 3 %32
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: passo 6, imagem 1 %32 How to Reupholster a Bench Cushion: passo 6, imagem 2 %32 How to Reupholster a Bench Cushion: passo 6, imagem 3 %32
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: passo 7, imagem 1 %32 How to Reupholster a Bench Cushion: passo 7, imagem 2 %32 How to Reupholster a Bench Cushion: passo 7, imagem 3 %32
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Linha de Chegada
Xochitl Vara
Membro desde: 01/26/22
169 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 580
