How to Restore a Torn Nike Flip-Flop
Introdução
Ir para o passo 1Nike Flip-Flops are a very common item in a person's wardrobe. Using these Nike Flip-Flops constantly causes wear and tear, which could be dangerous to the person wearing them. As the flip-flops tear they become unstable and can cause foot injuries like a sprained ankle. This guide will help protect you feet, by fixing the torn parts and making the Nike flip-flops more stable.
O que você precisa
Ferramentas
Exibir mais…
Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
Gently apply the adhesive on the torn parts of the flip-flop.
Make sure the torn parts are completely covered. Overspill is okay.
Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
The Nike Flip-Flop(s) are now restored and can be worn again.
7 outras pessoas executaram este guia.
2 comentários
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
Oh darn I see it now.lol
