Ir para o conteúdo principal
How to Resize Pants
How to Resize Pants
Haleigh Bingham
Haleigh Bingham e 5 outros colaboradores
Última atualização em April 17, 2021
45 segundos - 2 horas
Moderado
Introdução
Ir para o passo 1
This guide provides simple instructions for downsizing the width of pants. The steps have two parts: pinning and sewing. The included sewing techniques could be applied to many projects.
If the pants are more than six sizes too big, keep in mind that altering them might cause the loss of usable front pockets.
Before you begin, create a clutter-free space.
Minimal sewing experience is required.
  1. How to Resize Pants, How to Resize Pants: passo 1, imagem 1 %32
    • Put on the pants inside out.
  2. How to Resize Pants: passo 2, imagem 1 %32
    • Safety pin the waistband of the pants to the desired fit.
  3. How to Resize Pants: passo 3, imagem 1 %32
    • Pin the outside seam around both hips so that the pants are snug.
  4. How to Resize Pants: passo 4, imagem 1 %32 How to Resize Pants: passo 4, imagem 2 %32
    • Pin down the back seam and inseam so that the pants fit comfortably.
  5. How to Resize Pants: passo 5, imagem 1 %32
    • Take the pants off. Sew the back seam, following your pins.
    • Be careful when operating a sewing machine.
  6. How to Resize Pants: passo 6, imagem 1 %32
    • Put the pants on. Pin the rest of the inseam and the outside seam down both legs.
    • Our preference was to use the skinny jean cut. However, this sewing technique can be applied to any jean cut by simply adjusting the snugness of the fit as you pin.
  7. How to Resize Pants: passo 7, imagem 1 %32
    • Take the pants off. Then, cut off the extra fabric.
    • If you prefer, iron your newly created seams so that they lay open.
  8. How to Resize Pants: passo 8, imagem 1 %32
    • Enjoy your newly fitted pair of pants!
Conclusão
After following these steps, you should have properly fitting pants that were ill-fitting before.
23 outras pessoas executaram este guia.
Haleigh Bingham
Membro desde: 09/14/15
578 Reputação
Autoria de 1 guia
Equipe
5Comentários do guia
Thank you for this! I have a pair I really like that are huge in the hip and butt. So is it best to pin and make them fit better using the inseam, or the outside seam?
Matt and Amy Crowell - Responder
Thank you, I used your guide for my first time fitting pants; it was absolutely helpful!
Angelica Murillo - Responder
Muy original y más fácil de lo que había visto. A pesar que me defiendo bastante bien con la costura, esto de cambiar de una talla XL a una S, no lo hice nunca en un short, así que gracias por compartir tus conocimientos.
Ros CH - Responder
para que no se deshilen los bordes hay que darle unas puntadas en forma de zig zag a todos los bordes que se cortan.
DAVID MORENO - Responder
This guide is super helpful for resizing pants! Clear steps and easy-to-follow instructions. Thanks!
fundtaffrail - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 97
Últimos 30 dias: 395
Ao todo: 140,507
