Ir para o conteúdo principal
How to Replace the Tip of a Hiking Pole
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em September 20, 2024
10 minutos
Fácil
Guia colaborativo
Replacing a worn tip is a simple process that can extend the life of your hiking pole and ensure you stay safe on your adventures. We will show you a step-by-step solution on how to get your hiking pole as good as new!
  1. How to Replace the Tip of a Hiking Pole, Identify the repair area: passo 1, imagem 1 %32 How to Replace the Tip of a Hiking Pole, Identify the repair area: passo 1, imagem 2 %32
    • Prepare all the tools needed for the repair and locate the tip of the hiking pole that needs to be fixed.
  2. How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: passo 2, imagem 1 %32 How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: passo 2, imagem 2 %32 How to Replace the Tip of a Hiking Pole, Prepare the hiking pole: passo 2, imagem 3 %32
    • In order to protect the pole from scratching, secure it with scotch tape.
  3. How to Replace the Tip of a Hiking Pole, Remove the tip: passo 3, imagem 1 %32 How to Replace the Tip of a Hiking Pole, Remove the tip: passo 3, imagem 2 %32 How to Replace the Tip of a Hiking Pole, Remove the tip: passo 3, imagem 3 %32
    • Following the direction of the orange arrows, use an adjustable wrench to slide it fast along the hiking pole and push the tip outwards.
  4. How to Replace the Tip of a Hiking Pole, Insert the new tip: passo 4, imagem 1 %32 How to Replace the Tip of a Hiking Pole, Insert the new tip: passo 4, imagem 2 %32 How to Replace the Tip of a Hiking Pole, Insert the new tip: passo 4, imagem 3 %32
    • Insert the replacement tip manually by pushing it inwards.
  5. How to Replace the Tip of a Hiking Pole, Set the new tip in place: passo 5, imagem 1 %32 How to Replace the Tip of a Hiking Pole, Set the new tip in place: passo 5, imagem 2 %32 How to Replace the Tip of a Hiking Pole, Set the new tip in place: passo 5, imagem 3 %32
    • Use a hammer to secure the tip in its new position.
    • Note: only hit it once or twice with a hard tap.
  6. How to Replace the Tip of a Hiking Pole, Finished and ready!: passo 6, imagem 1 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 230
