Ir para o conteúdo principal
How to Replace the Pom Pom on a Beanie
Erin Shea
Erin Shea e 2 outros colaboradores
Última atualização em April 4, 2025
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
Instead tossing out the pom pom that fell off your favorite beanie, just follow these easy steps to reattach it and make your beanie look as good as new.
This guide requires basic sewing. If you're a beginner or don't have a lot of sewing experience, it may take a little longer, but it's a good first project to give sewing a try.
  1. How to Replace the Pom Pom on a Beanie, Beanie Pom Pom: passo 1, imagem 1 %32
    • Use sewing scissors to cut the string that attaches the pom pom to the beanie if it's still loosely attached.
  2. How to Replace the Pom Pom on a Beanie: passo 2, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 2, imagem 2 %32
    • Measure 10 inches of yarn.
    • Use your scissors to cut the yarn.
  3. How to Replace the Pom Pom on a Beanie: passo 3, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 3, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 3, imagem 3 %32
    • Pull one end of the yarn through the eye of a hand sewing needle until you have an even amount of yarn on both sides of the needle.
    • The point of the needle is sharp enough to pierce skin.
  4. How to Replace the Pom Pom on a Beanie: passo 4, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 4, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 4, imagem 3 %32
    • Push the needle through the pom pom, leaving a 3 inch tail of yarn.
    • Be aware of where the needle will exit and where your hand is holding the pom pom.
  5. How to Replace the Pom Pom on a Beanie: passo 5, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 5, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 5, imagem 3 %32
    • Poke the pom pom with the point of the needle at the same place you poked it in Step 4.
    • Pull the needle all the way through and keep the yarn on the needle.
    • You will end up with two strands of yarn, one on each side of the pom pom.
  6. How to Replace the Pom Pom on a Beanie: passo 6, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 6, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 6, imagem 3 %32
    • Push the needle through the top of the beanie.
    • Pull the needle all the way through until the pom pom is fixed against the beanie.
  7. How to Replace the Pom Pom on a Beanie: passo 7, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 7, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 7, imagem 3 %32
    • Push the needle all the way through one of the holes of the button.
    • Keep button in place and remove the needle from the yarn.
  8. How to Replace the Pom Pom on a Beanie: passo 8, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 8, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 8, imagem 3 %32
    • Put the second strand of yarn through the eye of the needle.
    • Poke the needle through the top of the beanie again.
    • Pull the remaining yarn all the way through to the other side of the beanie.
  9. How to Replace the Pom Pom on a Beanie: passo 9, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 9, imagem 2 %32 How to Replace the Pom Pom on a Beanie: passo 9, imagem 3 %32
    • Pull the yarn all the way through another hole in the button.
  10. How to Replace the Pom Pom on a Beanie: passo 11, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 11, imagem 2 %32
    • Tie another overhand knot.
  11. How to Replace the Pom Pom on a Beanie: passo 12, imagem 1 %32 How to Replace the Pom Pom on a Beanie: passo 12, imagem 2 %32
    • Cut off the remaining ends of the yarn, cutting close to the button.
Linha de Chegada
Erin Shea
Membro desde: 01/26/23
205 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-4, Morris Winter 2023 Membro de UC Davis, Team 2-4, Morris Winter 2023
UCD-MORRIS-W23S2G4
2 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 71
Últimos 30 dias: 840
Ao todo: 2,869
