Ir para o conteúdo principal
How to Replace a Watch Strap
domenicruffino
domenicruffino e 2 outros colaboradores
Última atualização em January 4, 2016
10 minutos
Fácil
Introdução
Ir para o passo 1
Millions wear watches everyday as a useful accessory. Most of the value in watches is in the body and mechanisms, not in the strap. A cheap watch strap failure can make an expensive watch useless if not repaired. Save money on watch repairs or make your watch more fashionable by reading this guide.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Replace a Watch Strap, Watch Strap: passo 1, imagem 1 %32
    • Begin by laying a soft towel or fabric on a table.
    • This will prevent accidental scratches during the repair.
    • We will be performing all repairs from the back of the watch, to avoid scratching the visible watch face.
  2. How to Replace a Watch Strap: passo 2, imagem 1 %32 How to Replace a Watch Strap: passo 2, imagem 2 %32
    • Before you begin, consider practicing with your tool to compress the bar.
    • Hold the watch with the face in your palm, with one end of the strap free to move.
  3. How to Replace a Watch Strap: passo 3, imagem 1 %32 How to Replace a Watch Strap: passo 3, imagem 2 %32
    • Insert your Spring Bar tool into the gap between the end of the watch strap and the watch body.
    • Press down and compress the spring. By pushing the bar away from the body, one end of the spring bar should come loose.
  4. How to Replace a Watch Strap: passo 4, imagem 1 %32 How to Replace a Watch Strap: passo 4, imagem 2 %32
    • Being cautious as to not damage the body or spring bar, slide the bar out from its hole and remove the strap.
    • Set this half of the strap with the spring bar aside until we remove the other strap.
  5. How to Replace a Watch Strap: passo 5, imagem 1 %32 How to Replace a Watch Strap: passo 5, imagem 2 %32 How to Replace a Watch Strap: passo 5, imagem 3 %32
    • Repeat steps 2-4 to remove the other end of the watch strap.
  6. How to Replace a Watch Strap: passo 6, imagem 1 %32 How to Replace a Watch Strap: passo 6, imagem 2 %32 How to Replace a Watch Strap: passo 6, imagem 3 %32
    • Replace the old or damaged watch straps by simply sliding the spring bars out and into the new straps
    • Be careful not to put the new straps on the wrong side of the body.
  7. How to Replace a Watch Strap: passo 7, imagem 1 %32 How to Replace a Watch Strap: passo 7, imagem 2 %32 How to Replace a Watch Strap: passo 7, imagem 3 %32
    • Begin the reassembly by sliding the bottom of the spring bar into its hole on the watch body.
    • Remember, always work from the back of the watch to prevent visible scratches.
    • Using your spring bar tool, compress the bar and slide back into place.
    • The spring bar should click when installed correctly.
  8. How to Replace a Watch Strap: passo 8, imagem 1 %32 How to Replace a Watch Strap: passo 8, imagem 2 %32 How to Replace a Watch Strap: passo 8, imagem 3 %32
    • Repeat step 7 on the other side of the watch.
    • Give the watch a tug to make sure all parts are installed correctly.
Conclusão
You have completed the fix! We hope this guide has helped.
5 outras pessoas executaram este guia.
domenicruffino
Membro desde: 09/29/15
281 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-2, Green Fall 2015 Membro de Cal Poly, Team 14-2, Green Fall 2015
CPSU-GREEN-F15S14G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 55
Ao todo: 11,179
