Ir para o conteúdo principal
How to Replace a Valve Spring on a Trumpet
Isaac Trotta
Isaac Trotta e 3 outros colaboradores
Última atualização em 22 de jul de 2015
5 minutos
Fácil
Introdução
Ir para o passo 1
This guide will teach to how to replace a spring in the valve of the trumpet.
O que você precisa
  1. How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, imagem 1 %32 How to Replace a Valve Spring on a Trumpet, valve spring: passo 1, imagem 2 %32
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: passo 2, imagem 1 %32 How to Replace a Valve Spring on a Trumpet: passo 2, imagem 2 %32
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: passo 3, imagem 1 %32 How to Replace a Valve Spring on a Trumpet: passo 3, imagem 2 %32
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Conclusão
Uma outra pessoa concluiu este guia.
Gear Up For Future Repairs
Shop all
Isaac Trotta
Membro desde: 02/24/15
125 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membros
Autoria de 15 guias
1Comentário do guia
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 8,702
