How to Replace a Tabla Skin
Introdução
Ir para o passo 1If you're looking to replace your tabla skin, here is a step-by-step process on how to do that successfully.
This guide is for musicians who have a tabla and notice the sound is not optimal, or may have ripped the tabla skin by accident and now is not playable. Fortunately for you, this guide goes in depth on how to re-strap a new skin onto a tabla.
The process of re-strapping the skin can be tedious, but with patience it can be done. This will be beneficial, because unfortunately tablas do get worn out over time and instead of having to buy a new tabla each time you can do the repairing yourself and save money.
O que você precisa
Peças
Ferramentas
Exibir mais…
Pull about half of the strap slack through the hole of the tabla skin.
Repeat the process of putting the strap over the tabla skin through the hole and over and through the ring at the bottom of the tabla.
Repeat this until the slack of the tabla that you pulled through is gone around half of the tabla.
If the skin gets loose over time, take the wooden pegs out and pull the straps around the Tabla to take out any slack, and put the wooden pegs back in again.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Very nice tutorial with clear pictures and steps mentioned.
