How to Replace a Sash Window Lock
Introdução
Ir para o passo 1If your window lock is broken or getting stuck when you try to lock or unlock your window, then it may be time to replace your lock, for both convenience and safety reasons.
This guide helps users successfully remove and replace a window sash lock with minimal effort. Some tips to follow for this guides are:
When removing the lock, keep the lock in a half-locked neutral position if possible. This position allows the user to easily access both screws that need to be removed.
When removing the lock keeper, keep pressure on the keeper when removing the last screw as the keeper will fall off the window when the screws are removed. This tip is mainly for those concerned with loosing old pieces, or for those with small children/pets that may get a hold of fallen pieces.
O que você precisa
Ferramentas
Measure the length between the two screws on the lock.
Measure the width of the lock from the screw to the keeper.
Put the lock into a locked position.
Hold the new lock in place while inserting and tightening the left 12.7 mm Phillips #2 screw.
Thanks for giving us a good idea about How to Replace a Sash Window Lock. You have well explained this topic
1Comentário do guia
This replacement of sash hardware information is really fantastic, know I want to say that it's really appreciated, We also are providing builder hardware if you want in bulk. You can contact us
