Ir para o conteúdo principal
How to Replace a Sash Window Lock
Seb S
Seb S e um outro colaborador
Última atualização em 14 de jun de 2021
4 - 7 minutos
Fácil
Introdução
Ir para o passo 1
If your window lock is broken or getting stuck when you try to lock or unlock your window, then it may be time to replace your lock, for both convenience and safety reasons.
This guide helps users successfully remove and replace a window sash lock with minimal effort. Some tips to follow for this guides are:
When removing the lock, keep the lock in a half-locked neutral position if possible. This position allows the user to easily access both screws that need to be removed.
When removing the lock keeper, keep pressure on the keeper when removing the last screw as the keeper will fall off the window when the screws are removed. This tip is mainly for those concerned with loosing old pieces, or for those with small children/pets that may get a hold of fallen pieces.
O que você precisa
Ferramentas
  1. How to Replace a Sash Window Lock, Window Lock: passo 1, imagem 1 %32 How to Replace a Sash Window Lock, Window Lock: passo 1, imagem 2 %32
    • Measure the length between the two screws on the lock.
    • Measure the width of the lock from the screw to the keeper.
    • These measurements help determine the size of lock you will need.
  2. How to Replace a Sash Window Lock: passo 2, imagem 1 %32 How to Replace a Sash Window Lock: passo 2, imagem 2 %32 How to Replace a Sash Window Lock: passo 2, imagem 3 %32
    • Move the lock into a neutral position.
    • Remove the 12.7 mm screw on the left side of the lock with a Phillips #2 screwdriver.
  3. How to Replace a Sash Window Lock: passo 3, imagem 1 %32 How to Replace a Sash Window Lock: passo 3, imagem 2 %32 How to Replace a Sash Window Lock: passo 3, imagem 3 %32
    • Remove the 12.7 mm Phillips #2 screw on the right side of the lock.
    • Remove the lock.
  4. How to Replace a Sash Window Lock: passo 4, imagem 1 %32 How to Replace a Sash Window Lock: passo 4, imagem 2 %32 How to Replace a Sash Window Lock: passo 4, imagem 3 %32
    • Remove the left 12.7 mm screw on the lock keeper with a Phillips #2 screwdriver.
  5. How to Replace a Sash Window Lock: passo 5, imagem 1 %32 How to Replace a Sash Window Lock: passo 5, imagem 2 %32
    • Remove the right 12.7 mm Phillips #2 screw on the lock keeper.
    • The lock keeper will fall off of the window once the last screw is removed. Be ready to catch it!
  6. How to Replace a Sash Window Lock: passo 6, imagem 1 %32 How to Replace a Sash Window Lock: passo 6, imagem 2 %32 How to Replace a Sash Window Lock: passo 6, imagem 3 %32
    • Line up the new lock keeper with the existing holes in the window.
    • Hold the keeper in place while inserting and tightening both the left and right 12.7 mm Phillips screws with a Phillips #2 screwdriver.
  7. How to Replace a Sash Window Lock: passo 7, imagem 1 %32 How to Replace a Sash Window Lock: passo 7, imagem 2 %32 How to Replace a Sash Window Lock: passo 7, imagem 3 %32
    • Line up the new lock with the existing holes.
    • Hold the new lock in place while inserting and tightening the right 12.7 mm screw with a Phillips #2 screwdriver.
  8. How to Replace a Sash Window Lock: passo 8, imagem 1 %32 How to Replace a Sash Window Lock: passo 8, imagem 2 %32 How to Replace a Sash Window Lock: passo 8, imagem 3 %32
    • Put the lock into a locked position.
    • Hold the new lock in place while inserting and tightening the left 12.7 mm Phillips #2 screw.
    • The new lock is now ready to be used!
Conclusão
Gear Up For Future Repairs
Shop all
Seb S
Membro desde: 01/19/21
157 Reputação
Autoria de 1 guia
1Comentário do guia
This replacement of sash hardware information is really fantastic, know I want to say that it's really appreciated, We also are providing builder hardware if you want in bulk. You can contact us
BuilderHardwarwe - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 46
Ao todo: 4,552
