Ir para o conteúdo principal
How to Replace a Jeans Zipper with Buttons
Luis Caraballo Ortiz
Luis Caraballo Ortiz e um outro colaborador
Última atualização em June 15, 2022
20 - 40 minutos
Fácil
Faltando Passos
Introdução
Ir para o passo 1
Have you ever put on a pair of jeans and when you try to zip them up it breaks? Broken zippers are a common struggle that most people suffer daily because of the quality of the product or just because of the years of use. When a zipper breaks, this does not mean the jeans are not wearable anymore. Instead, it can be a great opportunity to add some buttons and give them a second life.
In this guide, you will be able to remove a broken zipper and add new non-sewing buttons without the need for expensive machinery or knowledge. In just 20 minutes, you will have a new pair of jeans ready to wear!
  1. How to Replace a Jeans Zipper with Buttons, Zipper: passo 1, imagem 1 %32 How to Replace a Jeans Zipper with Buttons, Zipper: passo 1, imagem 2 %32 How to Replace a Jeans Zipper with Buttons, Zipper: passo 1, imagem 3 %32
    • Open the broken zipper and identify the stitches.
    • Take the seam ripper and insert it under the last stitch seen.
    • Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
    • Make sure to remove at least one half of the zipper.
  2. How to Replace a Jeans Zipper with Buttons: passo 2, imagem 1 %32 How to Replace a Jeans Zipper with Buttons: passo 2, imagem 2 %32
    • Insert the buttons tack to the right fly of the jeans.
    • Insert 2 or 3 button tacks, depending on the length of the fly.
    • Add textile glue to the pointed part of the tacks.
    • Adding glue to the tacks helps secure the buttons and avoids damage caused by the washing machine and daily use.
  3. How to Replace a Jeans Zipper with Buttons: passo 3, imagem 1 %32
    • While the textile glue is fresh, insert the buttons into the tacks and make sure they are secure.
    • You will notice the buttons are secure after you hear a clicking noise when pressing the buttons to the tacks.
  4. How to Replace a Jeans Zipper with Buttons: passo 4, imagem 1 %32
    • Cut three holes using the pointed part of the fabric scissor on the left fly of the jeans that correspond with the buttons on the right.
    • Make sure to open the fabric scissor and use only one blade.
    • Alternatively if you have access to a sewing machine, follow this guide to create the button holes.
  5. How to Replace a Jeans Zipper with Buttons: passo 5, imagem 1 %32
    • Using a needle and some thread, stitch the edges of the button holes to finish them.
  6. How to Replace a Jeans Zipper with Buttons: passo 6, imagem 1 %32
    • Make sure the buttons are secure, that they fit the holes, and that they open and close easily.
Conclusão
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 101
Ao todo: 4,717
