Ir para o conteúdo principal
How to Replace a Curtain Rod
Andrew Pfeiffer
Andrew Pfeiffer e 2 outros colaboradores
Última atualização em June 7, 2021
Nenhuma estimativa
Fácil
Precisa de melhores imagens
Faltando detalhes
Introdução
Ir para o passo 1
Curtains are a part of every household, and it's essential to change the curtains every so often to keep your house clean. Curtains break all the time, and buying new ones can be expensive.
This guide will explain how to replace a broken curtain rod with a new one. This guide is essential to all households because setting up curtains helps rooms stay cool or warm and blocks out sunlight. Curtains are also crucial because they help houses maintain privacy. Curtains are an essential part of every household, large or small. The repair will require hand and power tools for the installation and replacement of the curtain rods.
  1. How to Replace a Curtain Rod, Curtain Rod: passo 1, imagem 1 %32 How to Replace a Curtain Rod, Curtain Rod: passo 1, imagem 2 %32
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: passo 2, imagem 1 %32 How to Replace a Curtain Rod: passo 2, imagem 2 %32 How to Replace a Curtain Rod: passo 2, imagem 3 %32
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: passo 3, imagem 1 %32 How to Replace a Curtain Rod: passo 3, imagem 2 %32
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: passo 4, imagem 1 %32 How to Replace a Curtain Rod: passo 4, imagem 2 %32
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: passo 5, imagem 1 %32
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: passo 6, imagem 1 %32 How to Replace a Curtain Rod: passo 6, imagem 2 %32
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: passo 7, imagem 1 %32 How to Replace a Curtain Rod: passo 7, imagem 2 %32
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: passo 8, imagem 1 %32 How to Replace a Curtain Rod: passo 8, imagem 2 %32
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
Linha de Chegada
Andrew Pfeiffer
Membro desde: 02/22/21
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,346
