Ir para o conteúdo principal
How to Replace Keys on a Keyboard
Cooper
Cooper e 5 outros colaboradores
Última atualização em 16 de set de 2024
10 - 20 minutos
Fácil
Introdução
Ir para o passo 1
Do you have a keyboard with keys that do not work? Use this guide to replace your keys and return your keyboard to proper working condition.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. How to Replace Keys on a Keyboard, Individual Keys: passo 1, imagem 1 %32 How to Replace Keys on a Keyboard, Individual Keys: passo 1, imagem 2 %32
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: passo 2, imagem 1 %32 How to Replace Keys on a Keyboard: passo 2, imagem 2 %32
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: passo 4, imagem 1 %32
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: passo 5, imagem 1 %32 How to Replace Keys on a Keyboard: passo 5, imagem 2 %32
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Conclusão
Congratulations! You now have a keyboard with fully functional keys!
7 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Cooper
Membro desde: 02/24/15
493 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 24-6, Green Winter 2015 Membro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membros
Autoria de 15 guias
2Comentários do guia
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Responder
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 41
Últimos 30 dias: 132
Ao todo: 19,258
