Ir para o conteúdo principal
How to Repair an Elastic Loop on a Blouse
IAHN C ROSADO-LAUSELL
IAHN C ROSADO-LAUSELL e um outro colaborador
Última atualização em June 7, 2022
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
Elastic loops help to secure and tighten articles of clothing to your body.
If an elastic loop breaks, it can just look darn ugly, or make a garment completely unwearable. Use this guide to quickly reattach an elastic loop that has torn off.
Before beginning, be sure to acquire enough thread to perform the fix, at least 20 inches, because too little thread and the fix may not be possible.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: passo 1, imagem 1 %32
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: passo 2, imagem 1 %32
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: passo 3, imagem 1 %32 How to Repair an Elastic Loop on a Blouse: passo 3, imagem 2 %32
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: passo 4, imagem 1 %32
    • Simply cut the thread connected to the needle, and then any dangling threads.
Conclusão
Enjoy your revitalized garment!
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 77
Ao todo: 4,539
