Ir para o conteúdo principal
How to Repair a Tear in a Sleeping Bag
Ben Blischke
Ben Blischke e um outro colaborador
Última atualização em September 20, 2024
10 minutos
Fácil
Guia colaborativo
Sometimes, you're out there having the time of your life, enjoying an adventure, when suddenly, your sleeping bag suffers a tear. But don't worry! We’re here to support you with a simple solution that involves sewing the hole and rendering your bag 100% operational again!
For sleeping bags with a down feather filling, sewing the hole is not recommended as the content would still come out. If this is the case, check this guide on how to fix the problem using a fabric patch.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Repair a Tear in a Sleeping Bag, Identify the repair area: passo 1, imagem 1 %32 How to Repair a Tear in a Sleeping Bag, Identify the repair area: passo 1, imagem 2 %32 How to Repair a Tear in a Sleeping Bag, Identify the repair area: passo 1, imagem 3 %32
    • Locate the tear that needs to be fixed.
  2. How to Repair a Tear in a Sleeping Bag, Pin the area: passo 2, imagem 1 %32 How to Repair a Tear in a Sleeping Bag, Pin the area: passo 2, imagem 2 %32 How to Repair a Tear in a Sleeping Bag, Pin the area: passo 2, imagem 3 %32
    • Fold both ends of the split and hold them together with a line of pins.
  3. How to Repair a Tear in a Sleeping Bag, Stitch the area: passo 3, imagem 1 %32 How to Repair a Tear in a Sleeping Bag, Stitch the area: passo 3, imagem 2 %32 How to Repair a Tear in a Sleeping Bag, Stitch the area: passo 3, imagem 3 %32
    • Hold the pinned area with your hands and gently position it on the sewing machine.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Start sewing and remove any pins in the way of the sewing route.
  4. How to Repair a Tear in a Sleeping Bag, Clean the area: passo 4, imagem 1 %32 How to Repair a Tear in a Sleeping Bag, Clean the area: passo 4, imagem 2 %32
    • Use a pair of scissors to clean the loose threads.
  5. How to Repair a Tear in a Sleeping Bag, Finished and ready!: passo 5, imagem 1 %32 How to Repair a Tear in a Sleeping Bag, Finished and ready!: passo 5, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 151
