Ir para o conteúdo principal
How to Repair a Small Hole in Your Clothing
Ann
Ann e 2 outros colaboradores
Última atualização em February 24, 2025
15 minutos
Fácil
This is a beginner’s guide to repairing a small hole in clothing by sewing. This technique is easy enough to complete even in a fashion emergency. However, be careful when handling a needle. Never lose sight of your needle and always place it back in a safe spot.
  1. How to Repair a Small Hole in Your Clothing, How to Repair a Small Hole in Your Clothing: passo 1, imagem 1 %32
    • Grab the clothing you want to fix and lay it on a table.
  2. How to Repair a Small Hole in Your Clothing: passo 2, imagem 1 %32
    • Find the thread that matches the colour of the clothing you are going to repair.
    • Measure and cut a piece of string a minimum of 20x the length of the hole.
  3. How to Repair a Small Hole in Your Clothing: passo 3, imagem 1 %32 How to Repair a Small Hole in Your Clothing: passo 3, imagem 2 %32 How to Repair a Small Hole in Your Clothing: passo 3, imagem 3 %32
    • Insert the thread through the eye of the needle.
  4. How to Repair a Small Hole in Your Clothing: passo 4, imagem 1 %32 How to Repair a Small Hole in Your Clothing: passo 4, imagem 2 %32 How to Repair a Small Hole in Your Clothing: passo 4, imagem 3 %32
    • Pull the thread through until the length of both ends of the thread are the same length.
    • Tie the ends in a double knot.
  5. How to Repair a Small Hole in Your Clothing: passo 5, imagem 1 %32 How to Repair a Small Hole in Your Clothing: passo 5, imagem 2 %32 How to Repair a Small Hole in Your Clothing: passo 5, imagem 3 %32
    • Pinch the fabric to close the hole, and weave the needle back and forth through the pinch until the hole is sealed.
  6. How to Repair a Small Hole in Your Clothing: passo 6, imagem 1 %32 How to Repair a Small Hole in Your Clothing: passo 6, imagem 2 %32
    • Cut the thread from the needle and cut the leftover thread on both ends of the sealed hole.
  7. How to Repair a Small Hole in Your Clothing: passo 7, imagem 1 %32
    • The hole is completely sealed!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Ann
Membro desde: 09/19/20
172 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 67
Últimos 30 dias: 272
Duração total: 6,879
