How to Repair a Jammed Nozzle on a Perfume Bottle
Introdução
Vá para o passo 1While applying perfume, one may press down too hard causing the nozzle or sprayer to be jammed. This repair project involves a step-by-step procedure guide on how to fix a jammed nozzle on a perfume bottle. This repair requires you take extra safety precautions when removing the nozzle because the bottle is made of glass which can break easily if not gently handled.
O que você precisa
Ferramentas
Remove the nozzle from the bottle by taking the pliers and unscrewing the nozzle counterclockwise.
To reassemble the perfume bottle, follow these instructions in reverse order.
6 outras pessoas executaram este guia.
7 comentários
complimenti, bell'articolo!
This guide is stupid. BEFORE DOING THIS expose the nozzle and insert a sewing needle directly without removing the entire gasket. Don't cause unnecessary damage as most bottles have crimpted gaskets and are irremovable.
hey stupid dont talk $@$* and do a video. I need to see it,
Thanks now a needle is stuck in the tube
