Ir para o conteúdo principal
How to Repair a Hole in an Ugg Boot
Giselle Ochoa
Giselle Ochoa e 4 outros colaboradores
Última atualização em January 12, 2025
Nenhuma estimativa
Fácil
Introdução
Ir para o passo 1
Repairing a hole in an UGG boot can be a practical and cost-effective solution to extend the life of your favorite footwear. Whether it's a puncture, tear, or wear-induced hole, restoring your UGGs can be done with a few simple steps.
Once the boot is gently washed and dried, the suede patch can be placed securely and dried completely to ensure a durable repair. With a bit of skill and the right tools such as a suede patch, scissors, and an iron, you can restore your beloved UGG boots, keeping them cozy and stylish for many more seasons to come.
  1. How to Repair a Hole in an Ugg Boot, How to Repair a Hole in an Ugg Boot: passo 1, imagem 1 %32
    • Using a sponge, wash the boot with soap and water, then let it dry overnight.
  2. How to Repair a Hole in an Ugg Boot: passo 2, imagem 1 %32
    • Make sure there is no fleece sticking out of the boot where the hole is by pushing it in with a pen or pencil.
  3. How to Repair a Hole in an Ugg Boot: passo 3, imagem 1 %32
    • Stuff the boot with paper or trash bags so that it holds its shape.
  4. How to Repair a Hole in an Ugg Boot: passo 4, imagem 1 %32
    • Using scissors, cut out the size of the suede patch you will need to cover the hole.
  5. How to Repair a Hole in an Ugg Boot: passo 5, imagem 1 %32
    • Turn on the iron and set it to silk.
  6. How to Repair a Hole in an Ugg Boot: passo 6, imagem 1 %32
    • Put the suede patch over the hole and a shirt over the suede patch.
  7. How to Repair a Hole in an Ugg Boot: passo 7, imagem 1 %32
    • Iron the boot for 20 to 30 seconds.
  8. How to Repair a Hole in an Ugg Boot: passo 8, imagem 1 %32
    • Using the suede dye, thoroughly saturate the boot.
  9. How to Repair a Hole in an Ugg Boot: passo 9, imagem 1 %32
    • Let it fully dry for a day, and then you can wear it.
Linha de Chegada
Giselle Ochoa
Membro desde: 10/25/23
169 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 29
Últimos 30 dias: 115
Ao todo: 4,714
